6 posts / 0 new
Last post
randy n
6x6 post
I have a 6x6 post that is supporting a deck and the 16 x16 shelter when I notch out for the 2x10 does that compromise the support value of the 6x6 to hold the roof help
dj1
Re: 6x6 post
Not sure what you're asking. Can you re-phrase your question with a better description of the situation?
randy n
Re: 6x6 post
because i have cut a one and a half inch by 9 ad a half inch notch out of a 6x6 can it still be used as a post for my roof
jkirk
Re: 6x6 post
yes it can, its fine, just be sure to add atleast another 2x10 to it and install carriage bolts through the post and beam
dj1
Re: 6x6 post
I see what you want to do now.
What jkirk says will work, but notch no more than 1-1/2" off the posts.
I'd do it differently: use a 4x10 on top of the posts, with bolted Simpson connectors.
canuk
Re: 6x6 post
Yep -- just like Mr. Kirk said -- I would also use construction adhesive.
A *let in * connection like this is very strong. The 2x10 simply fills in the material you removed ( pretty much considered a squash block ).
TV Listings
Find TV listings for This Old House and Ask This Old House in your area.
