5 posts / 0 new
Last post
dduhon
5/4 wood deck installation
dduhon
In regard to installing 5/4 (1x6) treated wood decking. Do I need to install it with the growth rings facing a certain way, to help stop twist and cupping?
dj1
Re: 5/4 wood deck installation
dj1
Yes, that will make your deck look more uniform.
MLBSF
MLBSF
install them with rings looking like they're an upside down bowl. then screw the deckboards to the joists, 2 screws per joist about 1" in from the edge of the decking board.
ordjen
ordjen
If you are buying dedicated 5/4 decking lumber, the point is mute since the back side will normally have several small groves cut into it along the length of the board. This is to aid in controlling cupping or bowing of the board.
Gizmo
Gizmo
If you take a close look at the lumber the growth rings could be on the edge.......
Sponsored Stories
TV Listings
Find TV listings for This Old House and Ask This Old House in your area.
