2 posts / 0 new
Last post
3 way switch
I have a 3 way dimmer that I would like to put in a single switch toggle...
don't need the 3 way connection . There are 2 red wires.. can I just cap one of them and just not use it..
This dimmer will control one ceiling fixture that happens to be a light and fan. I control the fan and light something with pull chains.
thank you
Re: 3 way switch
No, you cannot use a dimmer to control a fan/light that is only on one switch. It will either burn up the fan or the dimmer.
For this fan, get a fan remote. They are $30 and you can safely dim the lights and control the speed of the fan.
Yes, you can use a three way dimmer for a single pole application. You would cap off one of the reds. If the dimmer seems upside down, try the other red (you'll know what I mean if it happens).
Sponsored Stories
TV Listings
Find TV listings for This Old House and Ask This Old House in your area.
