6 posts / 0 new
Last post
rudyruee
220/110
i got a shed prewired w ceiling lites and bench w pegboard. my question is there is a 220 outlet id like to temporarily step down to 110. is that possible? if so how w/o rewiring.
JLMCDANIEL
Re: 220/110
It will depend on which type 220 receptacle it is and how it is wired.
If it is a 4 prong receptacle you have 2 hots, a neutral and a ground. Wiring a plug with a black wire on either one of the hots and white on the neutral , and ground will give you 120 volts .
It it is a 3 prong outlet and has 2 hots and ground, then no, because you should not use ground as a current carrying conductor.
Ernie_Fergler
Re: 220/110
My advise is to call an electrician. Changing outlets, switches, etc. is one thing, but this is more involved.:D
canuk
Re: 220/110
The breaker for this circuit would also be a consideration --- depending on the rating may need to be changed to an appropriate size and type ( single pole from a bouble pole )
A. Spruce
Re: 220/110
Hey! How did you make the D backwards?!?!?!? :eek::D:D
canuk
Re: 220/110
duh on me :o:D
Sponsored Stories
TV Listings
Find TV listings for This Old House and Ask This Old House in your area.
